Correct you will learn not my opinion fact parts are very limited if I'm not wrong cars have been totaled for rear light damage and other things that would be commonplace in today's market but that's what you drive a rarity good luck ..jerz.....WOW... that almost looks like the result of either a thermal or chemical reaction.
Sent from my SM-T357T using Tapatalk
The corvettes do almost the same thing but at least you can buy replacement lens for a couple hundred dollars each that have fixed the problem with better material. Just too few xlrs for them to do anythingI think you should call the engineers at General Motors and let them research your headlamps maybe they couldn't help and also locate the part and give it to you this is not supposed to happen
Adam.. Until you can find a replacement headlight or a solution,,,you might want to add the XPEL H1417-DS - Dark Smoke Headlight Protection Kit to at least camouflage this unacceptable appearance. I'm aware this wouldn't solve your problem, but may diminish the embarrassing factor. I put this product (clear) on my XLR headlights to protect them, and was quite satisfied. Good luck!
p z
XPEL H1417-DS - Dark Smoke Headlight and Fog Light Protection Kit | eBay
