Help! Inside door release button mostly doesn't work - exterior button works every time
wardlws
North Alabama
2005 Blue Steel / Shale
This one has me stumped...
My driver door interior latch release button only works 1 out of every 5-10 tries. I don't think it is the button itself, since it will lower the window an inch every time.
The outside door latch button works every time (both lowering the window and releasing the door latch). As a long shot, I have taken outside switch apart, cleaned, and reassembled... no change to either the inside nor outside release.
I disconnected both harness connectors from the BCM, sprayed electrical cleaner, let dry, and re-connected. Also no change.
Lastly, I replaced the door latch with an OEM part... no change. Outside button works every time. Inside button will lower the window every time, but only release the latch on rare occasion.
Since the inside button lowers the window, but doesn't trigger the door latch... what could it be? BCM? Ground? Design Flaw?
I have to hold the button a little longer sometimes or hit it twice. I would inspect and clean the inside button and the wiring to it.
Yep, I've tried holding the inside button. The window stays an inch down so long as I hold the button. To me, this sounds like the interior release button is working.
Has anyone had any similar issues with the inside button lowering the window and not unlatching the door?
To my dismay... it was indeed the inside door release button! I'm a bit dumbfounded by the design here. It seems like the car has two separate circuits that go through the switch: one to lower the window an inch, and a second circuit to release the door latch! So, it may very well be... one circuit inside the switch can go bad and leave the other circuit intact. My switch would lower the window, but not release the door.
As in this post, you can buy the inside door release switch for the corvette, and easily replace the button with the XLR button: https://a.co/d/0cQ906WU
Also, I forgot to order the door panel retainer pins / clips. You will very likely break at least one: https://a.co/d/02FjHzmE
