Rule62
Mike, They appear to be close in size, a little bit larger diameter. Don't know if the speed rating is the same and don't seem to be a high mileage tire at a 220 rating. You may want to do 255 all the way around and give you the ability to rotate the tires. I'll be needing tires this fall as well and haven't decided what I'm going to do yet.
I just picked up an '06 V with 40,400 on it. It has OEM tires that were installed on 3/11 went the car had 26K on it. Today I had the painted rims swapped out for some freshly chromed ones and got to inspect the tires up close. I figure there's maybe 10K left on the outside. I was just wondering if you reached a tire decision and what your experience was following up.
Thanks...
