Steve Lee
When I push the open button to open that storage area it comes out very slowly. I don't think that is normal? Should I lube it with some WD 40?
Silicone grease would be a better choice and it won't run off as quick
IMO,,,slow is normal and better.
had an 05 for 6yrs,same thing, tried lube and other things no luck, I came to the conclusion slow was normal"Zen"says,"In my opinion slower is better?" But how slow is slow?? Mine takes about 11 seconds to fully extend. To my way of thinking that's too slow. How say you you ??
What is the hurry? Plenty of other storage areas......
If you can"t accept advise then don"t ask for assistance. Accept that it opens slow.
Thanks. I think if yours takes only -5 seconds, that my 13 seconds is al little slow, and it was not designed that way. I'll lube it and see what happens.Thanks again for the advise.Well Steve, lube it up with your WD-40 idea and gain a few seconds......you will be happy then and can sleep at night...
Mine took exactly 4.7 seconds to open,,, guess I got a good one that wasn't assembled on a Friday Possibly others with this critical, time wasting issue can respond to help you out?
When we first got our X, the center pop out button came apart on me. When I started looking at it to see how it worked, it had some kind of goo/lubricant on it. It's entirely possible that the stuff in your car is gumming things up. You'll have to take it apart and clean it. I assume that's what you're talking about and not the hinge itself on the bottom
The latch does come apart, and you don't have to break anything to get at it. It's all held together by plastic pressure clips. I know, I've done it.
You sir are the WIZ!! I get more answers and info from you than anyone! I think it is safe to assume that those "clips" can be seen from the inside?? is that correct, and how many are there??
