Try Method #3, but allow some time to do it.
Transmitter Programming Domestic
Important
When a remote control door lock receiver (RCDLR) is replaced the original key fobs become obsolete; the key fobs can only be programmed to the original RCDLR. Key fobs and the RCDLR can only be transferred to another vehicle as a complete set. Additional new key fobs programmed to a RCDLR cannot be reprogrammed to another RCDLR or another vehicle.
Important
Do not operate or program the key fobs in the vicinity of other vehicles that are in the keyless entry program mode. This will prevent the programming of the key fobs to the incorrect vehicle.
There are 4 methods for programming key fobs. Up to four key fobs may be programmed to the RCDLR. Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1208587&evc=sm&pubid=423&cellId=52171&mspsdsubkey=2942#ss1-1208587">
Method 1 - Key Fob Quick Learn
This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if two fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important
This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
- <LI type=1>The vehicle must be OFF. <LI type=1>Open the rear compartment. <LI type=1>Place a known key fob within the interior of the vehicle. <LI type=1>At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. <LI type=1>The drivers information center (DIC) will display a message: READY FOR FOB X (X = fob 2, 3, or 4). <LI type=1>Place the replacement key fob in the glove box fob pocket with the buttons facing right. <LI type=1>A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED. <LI type=1>If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
- Operate the active portion of each key fob in order to verify correct system operation.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1208587&evc=sm&pubid=423&cellId=52171&mspsdsubkey=2942#ss2-1208587">
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicles mechanical key, and a scan tool.
Important
This procedure is not available when the maximum number of Fob's (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
- <LI type=1>The vehicle must be OFF. <LI type=1>Open the rear compartment. <LI type=1>Place a known key fob within the interior of the vehicle. <LI type=1>At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. <LI type=1>Install a scan tool. <LI type=1>Use the scan tool, to access the following:
- Vehicle Control Systems
- Computer/Integrating Systems
- Module Replacement/Setup
- RCDLR
- Program Key Fobs
<LI type=1>Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to. <LI type=1>Place the replacement key fob in the glove box pocket with the buttons facing right. A beep will occur indicating programming completion. The previously known fob is now erased. <LI type=1>If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming. <LI type=1>Remove the scan tool.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1208587&evc=sm&pubid=423&cellId=52171&mspsdsubkey=2942#ss3-1208587">
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10 minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicles mechanical key.
Important
All previously programmed key fobs will be erased upon completion of the 30 minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
- <LI type=1>The vehicle must be OFF. <LI type=1>Open the rear compartment. <LI type=1>Place the replacement key fob in the glove box pocket with the buttons facing right. <LI type=1>At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. <LI type=1>The drivers information center (DIC) will display a message: OFF/ACC TO LEARN. <LI type=1>Press the OFF/ACC portion of the ignition button. <LI type=1>The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time. <LI type=1>When the counter reaches 0, DIC will display OFF/ACC TO LEARN. <LI type=1>Repeat steps 6-7 two more times, for a total of 30 minutes. <LI type=1>A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2. <LI type=1>Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode. <LI type=1>If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1208587&evc=sm&pubid=423&cellId=52171&mspsdsubkey=2942#ss4-1208587">
Method 4 - Service Programming System Fob Programming
This procedure is a 10 minute relearn procedure using the Techline Terminal with SPS software. Once the 10 minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
- <LI type=1>Place the vehicle in the Vehicle On, Engine Off mode. <LI type=1>Connect a scan tool to the vehicle. <LI type=1>Insure that all power consuming devices are turned OFF on the vehicle. <LI type=1>With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions. <LI type=1>Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software. <LI type=1>Turn the vehicle OFF. <LI type=1>On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above. <LI type=1>Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle. <LI type=1>With a scan tool, select Program ECU under Service Programming System. <LI type=1>At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure. <LI type=1>When the 10 minute relearn procedure has completed, use the scan tool to access the following:
- RCDLR
- Program Key Fobs
<LI type=1>Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to. <LI type=1>Place the replacement key fob in the glove box pocket with the buttons facing right. A beep will occur indicating programming completion. The previously known fob is now erased. <LI type=1>If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming. <LI type=1>Remove the scan tool.
