1) Obtain and chill beer.
2) Lower the window.
3) Remove the plug behind the wooden pull handle.
4) Remove the fasteners behind the plug.
5) Remove the courtesy lamp at the bottom of the door.
6) Remove the fastener securing the courtesy lamp housing.
7) Use a plastic trim removal tool to remove the retaining fasteners that attach the panel to the door. Do this carefully to avoid damaging the fasteners. Pry out the first fastener --located 2" up from the bottom at the rear of the trim panel, to better see the next fasteners, then move forward to the remaining fasteners.
8) Lift the trim panel upwards from the top fasteners to remove it from the door.
9) Disconnect the electrical connector.
10) Set the trim panel aside.
11) Transfer any trim panel retainers to the panel that remain on the door.
12) Re-position (or replace the switch if the housing is damaged) and reverse the disassembly steps, until you reach #2.
13) Disregard step 1 and begin consuming your chilled beer.
14) Take a long look in the mirror and marvel at your engenuity and resourcefulness!
15) Repeat step 13 as required.
CC
