klausman
My 2006 XLR recently stopped loading the Map DVD. It gives the "No disc inserted" message. When I try to insert the disc, the unit won't load it. Appreciate any help here. Thanks
Verify the DVD unit can read disks by inserting a DVD while parked. If it plays, the map disk is probably hosed or needs to be cleaned. If it doesn't, use a DVD cleaner disk to de-funk the laser's lens. Maxell(R) Lens Cleaner For DVD-LC DVD | Staples(R)
If that doesn't work, it's time to start shopping for a new head unit. In that case, you'll get modern functionality installing a new (non-GM) head unit. There's a lot of info as to what's needed archived here, using the Search function.
CCC![]()
I am embarrassed to post this
but thought it to be good info regardless.
I get the same message. My DVD player plays DVD's beautifully. The disk is clean and shiny, and loads perfectly on my computer. Something's fishy here. Did GM build in an obsolescence date?Verify the DVD unit can read disks by inserting a DVD while parked. If it plays, the map disk is probably hosed or needs to be cleaned. If it doesn't, use a DVD cleaner disk to de-funk the laser's lens. Maxell(R) Lens Cleaner For DVD-LC DVD | Staples(R)
CCC![]()
