Video: How to go about Repair?
Jesse
New Member
Crestview ,fl
2004 xlr
Checked the sensor and it’s OK
The code say the right front wheel speed sensor supply (subfault)
C0035-abs
System disable information stored
C0561-71-abs
Can anyone give me some information how to go about fixing this?
What was your method for checking the sensor and determining it’s ok?
I used a multimeter to see if a current was there and check the wire to see if it had voltage to both had reading and no break in the wires
Campaign PIC4487 may have some insight, G402 has the note “Transmission harness, on the underbody, on the RR frame by the RR wheel well, ground for CKT1050.”
And the diag table for c0035, with the values you can check with your multimeter. Step 9 is cut off but it’s “replace EBCM” and step 10 is just “clear codes and test drive.”
