carterchapman
I am troubleshooting a coolant leak under the left front - under the radiator. I have a couple of questions:
I have an early build 2005 (thanks for the build sheet Bruce!) - Oct '04, so I have the following "expected" items so far:
1. Melted headlight bezels
2. A proper working top, but every now and then my trunk does not unlatch but the motor tires to raise it when I push the license plate button, so I figure I have all early sensors, and this may be a future problem of "greater magnitude". This is a topic for another thread. And,...
3. The small coolant leak.
I will remove my intake assembly and determine if it is a hose or the radiator this weekend, but I noticed the follwoing step in my shop manual for radiator removal:
Recover the freon from the A/C system.
I've removed and replaced a number of GM radiators without "bothering" the A/C system, but is this truly a necessary step in radiator removal?
That takes it out of the hands of most of us if it is.
So now (drum roll please), the question:
Have any of you removed your radiator and were you able to do it without removing/replacing the freon?
Thanks in advance.
Thanks in advance.
