What are the key service intervals?
fastforward
So. Cal
The owners manual basically indicates service at 50K and 100K. I got a note from the dealer stating I was due for 40K service. What does that entail and do you do it? I figured I was good with just oil changes and air filters.
Anyone take their XLR in more frequently for service? I only drive highway miles.
You may need to clean the throttle body bore. Check/replace the cabin filter. Check air filters. You could do a brake fluid change/flush. That's about it. There isn't a fuel filter to change (it's in the driver's side fuel tank).
You could change the transmission filter and fluid around 50,000 miles. If you do, install Dexron VI transmission fluid. You could also do a drain and refill of the cooling system and replace the thermostat.
Bruce :wave:
Bruce :wave:
Thanks Bruce.
Any thoughts / concerns about installing the M2W exhaust switch mentioned in another thread?
