rsvette182
Hey all… I recently got an ‘06, 140k miles, the tail lights were repaired by the previous owner, the only issue is the inner white strip on the passenger side tail light comes on with the running lights (when it should just be the outer strip of lights) other than that they both work perfectly though. That doesn’t bother me, what does though is the right turn signal “hyper flashes,” which is quite annoying. Yes, both front turn signal bulbs are incandescent and work as they should. I was wondering if there is any way to trick the bcm into thinking the lights work as they should? If anyone has any input, I’d appreciate it.
