I just discovered this and thought it a little odd. I expect it is operating as designed.
I stopped to pick up a passenger and put the car in park (engine running). The passenger door would not open (locked). I pressed the interior door button, no difference. The drivers door opened fine and I got out with the fob in my pocket, walked around the car, and the passenger door opened fine. Hmm, OK we all know sometimes this car gets "confused" and there are anomalies that come and go, just deal with it.
Then, arriving at the destination the passenger was locked in, the door would not open. Not really having used the manual door unlock buttons it took a second to find it and unlock the door, which worked. I then found the setting for the auto door unlock that I changed from "Driver Only" to "Both" and things started working like what I was used to. I'm not sure how that had changed or how long it had been set that way but do know it hasn't always been that way. Most of the time my passenger has no thumbs to press the button despite having four legs.
Finally, I get to the real point of the post.... Would it not be reasonable to think that the door would open from the inside regardless of the lock status? When is it necessary to lock someone in? Is this some kind of "child-proof" lock?
An aggravation that I noticed once before, but can accept for safety reasons, was that if the door is accidentally not fully closed you must stop before attempting to open and re-close the door.
