X
XLR KEN
HELP>
Recently my 05 XLR has been showing inaccurate gas gauge levels. It would appear that it is only moving between 1/4 and 3/4 levels, no matter how much fuel is in the tank.
Today, after having driven 330 miles since the last fill-up, the gauge was at 1/4 yet I put in over 15.5 gal. After it was filled (pump auto shut off), it only showed 3/4 full. This has been goning on for a few weeks.
It is either the fuel sender in the tank or the instrument cluster. I more strongly suspect the stepper motor in the cluster but don't know about it's actual construction or if software could be a factor.
Has anyone had a similar problem?
I searched the Tech Bulletins and only found three notices related to "Eradic Fuel Gauges" and none really gave me a hint of any related issue.
<O
</O
TSB No.: 050604041 NHTSA No.: 10017536 TSB Date: ffice:smarttags" /><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com
</st1:date>June 1, 2005 Date Added to File: <st1:date Year="2005" Day="9" Month="11">November 9, 2005</st1:date><O
></O
Failing Component: Fuel System, Other<O
></O
Summary: Erratic fuel gauge readings, fuel gauge reads empty when there is fuel in tank, diagnostic trouble code P0463 set, service fuel system message displayed.<O
></O
<O
></O
TSB No.: 3551 NHTSA No.: 10017276 TSB Date: <st1:date Year="1901" Day="1" Month="1"><st1:date Year="19" Day="1" Month="1" ls="trans">January 1, 19</st1:date>01</st1:date> Date Added to File: <st1:date Year="2005" Day="31" Month="10">October 31, 2005</st1:date><O
></O
Failing Component: Fuel System, Other Storage Fuel Gauge System<O
></O
Summary: Service vme - fuel gauge erratic or defaults<O
></O
<O
></O
TSB No.: 3474 NHTSA No.: 10014918 TSB Date: <st1:date Year="1901" Day="1" Month="1"><st1:date Year="19" Day="1" Month="1" ls="trans">January 1, 19</st1:date>01</st1:date> Date Added to File: <st1:date Year="2005" Day="11" Month="5" ls="trans">May 11, 2005</st1:date><O
></O
></O
Summary: Erratic fuel gauge - service vme.<O
></O
<O
></O
HELP.............
XLR KEN
<O
<O
<O
<O
HELP.............
XLR KEN
