XFireXLR
- Joined
- Sep 28, 2008
- Messages
- 745
- My XLR/V(s)
- 2006 Gold Mist Met. XLR
On my last two sets of Michelin OEM run flats both rear tires suffered from irregular tread wear (different tread wear on each tire). The first set I got approximately 9100 miles and 13000 on the second. When I had them replaced Michelin gave me a 50% discount on the replacement and now 60% on the most recent set. The tire tech and Michelin said that the tires should be inflated to 38psi rather than 30psi as indicated on the door sill. The tire tech said that the 30psi rating is what GM recommends for a more comfortable ride, he suspects that is the reason for the irregular tread wear. Unfortunately now I am getting a "high tire pressure" warning in the DIC, has anyone else experience this issue?
