cornishon
I've owned my 09 XLR for about 6 months now. About 3 months ago I started having an intermittent problem with putting the top up. So far I had about 4 instances where the top would refuse to close on my first try. Here's what happens, usually after driving in the city for 30-40 min with the top down.
- with engine running, transmission in park, doors closed, press the top button to close the top
- trunk opens normally and lid goes to fully open position
- the tonneau cover refuses to fold under trunk - the pump keeps working but nothing happens, as if the tonneau is stuck to the trunk.
In three cases I was able to close the top by simply cycling back to "top open position" (trunk lid goes to closed and latched) and then after waiting few seconds, pressing and holding the top switch.
Well, this weekend this did not work : the trunk lid remained stuck in open position and would not close neither by pressing the trunk button on the bottom of the trunk lid, nor by using the top open/close switch. I decided to wait and give it a try later. First time nothing happened, but after 2 tries (shut engine off, wait, turn engine on) the top finally closed.
On Monday I look the car to the dealer. As I suspected, this kind of malfunction is of the worst "could not reproduce" type. The technician checked all sensors and everything was in range, and there were no codes stored in the BCM. Also, the top worked just fine at the dealers.
My best guess would be a bad electrical connection somewhere in the top harness that prevents the tonneau from folding and the top from completing the cycle, but my hope is that someone on this forum may have had the same malfunction and had it all figured out.
Thanks!
Pavel
Thanks!
Pavel
