- Thread starter
- #41
Vasir
Lex, you're absolutely right- I manually opened the top completely with the help of CC's advice.
As far as the car not shifting out of park- I recalibrated the brake sensor, and it didn't change...
then it dawned on me: I remember the tow truck driver fiddling with the shift selector trying to get it out of park before I gave up, jacked it up and manually shifted it to neutral so we could roll it out of the p/o's garage and load on to the flatbed. I had reconnected the linkage underneath and set the car in park but I was curious if the shifter wasn't set back correctly. I opened the shifter, loosened the screw, reattached it, retightned the screw and voila- it came out of park.
I drove the car around the block a couple times, letting the neighbors hear the stainless cat back exhaust before I parked it back in the garage. I'll be buttoning up what I've opened and tackling the car in reverse order from the crank shaft sensor not being calibrated back to the last thing being the suspension and trunk/top module.
More to follow soon! Thank you again, everyone- I wouldn't have gotten anywhere with this car without the help of this forum!
ill upload some pics soon as well
