cobratoo22
The heavier bar is meant to be used with the beefier tires like th v or the zo6 has.
you would have gotten a lot better performance ride for a whole lot less money with the z06 bilsteins and simulators. You are paying for the upgraded shocks for the 08 model most likely but not getting the better ride if you have the older suspension module.
I'd always believed that going stiffer on rear sway bars leads further into oversteer, as opposed to understeer, as many posts on here have stated. By no means am I suggesting that any of these bars are going that far, but that's the theory: oversteer, where the rear loses grip before the front.
Most OEM set ups will tune suspension so that, once the limits are exceeded, the front end "pushes," which is understeer. The idea here is that understeer is easier for the everyday driver to recover from. Let off the gas and usually it stops.
Oversteer causes the rear end to lose grip first. Once that happens, many drivers will not be comfortable countersteering to avoid a spin-out (see Porsche, 911, older models).
The XLR does not seem to have nasty tendencies, due in part to the near 50-50 weight balance, part to decent suspension design and tuning and as a back-up, StabiliTrack. That last one can save your a$$. Turn it off at your discretion.
Most of us do not approach, let alone attempt to exceed what the platform is capable of, so I wouldn't place too much weight on the details. Just knowing that having a rear sway bar makes cornering one of these vehicles more enjoyable is enough for most of us.
Thanks for the updated parts list.
John B.
