Richiez
Does any tire co make a low profile runflat tire?
So has anyone gone away from the run flats and ran normal tires? if so did you experience a better ride and performance? I am sure you get better mileage as the run flats mileage is horrible. I am looking at running regular tires instead of run flats ad would like any feedback from those of you who have
I'm also anti-run flat, but I have given it second thoughts after someone pointed out the risk of damage from a "fast flat" (even if it's not a blow out), especially to the front end. I haven't finished thinking about it but that will be in play when it's new tire time. I'd rather not deal with car damage, subject to guessing at risk vs. benefit.
My apologies in advance for piggy-backing this thread, but it is in the ball park...
I'm on the cusp of adding new rubber and am seeking final assurance that running 255/40/19's (rear stock size for V's) on the front as well will cause me no future issues relative to rubbing, cornering, handling, aligning, rotating, et al. I'm past the run-flat argument and will stick with the non's... Michelin this time (Pilot Sport A/S 3) versus the Pirelli's that were new at my purchase (P Zero Rosso's in stock fitment but non-run flat). Thanks!
I have been warned several times that my original stock run flats need to be replaced soon or dire
consequences await….
Decided to simply replace with the same original stock run flat that came with my 2008 XLR: Goodyear; Eagle RSAs; P235 50ZR 18 97W.
After several weeks of looking, I am advised that these run flat tires have been discontinued by Goodyear.
Never-the-less a set were located for me in Louisiana and are on the way; however it took some searching.
I pass this on because it looks like XLR run flat options are narrowing. The Michelin Pilot HX MXM4 ZP tire
appears to be the most available. That was what my local Cadillac dealer was offering after their unsuccessful search
for stock replacement Goodyears.
Steve
