mtrocket
Just... To... Be... Sure (and I've never had occasion to do this before):
It IS permissable to open the top only a portion of the way and then stop... right? Just take your finger off of the button at the point where you feel you need it? Can it be incrementally adjusted from that point without issue? Is there any fob control for the top mechanism at all (except for opening and closing the trunk, of course)?
I expect my tint guy to need the top partially retracted and the Wind Restrictor removed to get at the back glass (reason I'm asking). TIA!
BoughtTheXLR said:Yes you can stop the open/close at any point by removing finger from the switch. I do this every so often to clean the inside of the rear <NOBR>window</NOBR>. I turn the car off once the top is positioned to my liking.
No fob control of the top is documented. I'd hold the trunk button down to see if then the top would retract, but I know how disappointed I'd be. !
Yes, you can stop the top where you want it. But... when you put the top back up or down, continue the cycle from where you stopped the top. In other words, if you were putting the top down when you stopped, continue putting it down before putting the top up; if you putting the top up when you stopped, continue putting it up before putting the top back down.
No, no fob control of the top... only with the button.
