Help! Wheel well push pins
boydavid
franklin,tn
2007 Black Base
Is there a way to remove the black pushpins that secure the plastic housing in the wheel wells without destroying the pushpins so I can reuse them?
Thanks.
Thanks.
You can pull them out sometimes without damaging them but there no guarantee that you will not have to replace some of them
Go to Amazon, you can buy a bag of them fairly cheaply before you start your task. Invariably, you'll break at least one as they get quite brittle with age
thanks
thanks. I wasn't sure I could pull them straight out until I found a video on youtube. It was easy and they were re-useable. Thanks.
I bought some to keep on hand. I'm not sure if they are all the same size but I've had my trunk lid inside cover off a few times and they break after awhile and need replaced.... BTW if ever need to replace a or want to switch out bulbs on the trunk lid area you will need to remove the inner lid cover! Have a nice weekend!
I replaced the third brake light bar couple of months ago. That also entails removing the trunk lid liner. Glad I had some extra pins on hand because I had several of the old ones break off
For future reference, the rear decklid liner push pin (retainer) P/Ns are : 11519949 They are used in other locations as well.
