Lifting rear of XLR
Kenny Franklin
Bardstown, Ky
2006 Light Platinum XLR
I would like to remove the rear wheels to clean them and inspect the brake pads. Is the aluminum cross member behind the leaf spring substantial enough to lift the rear and wood using a block of wood be beneficial in distributing the weight.
Yes, you can do this. You may need a way to get the rearend high enough to get jack
with protective wood under the cross member, AND you need to use jack stands once you
get the car high enough.
I have done that too, but used 2 floor jacks than add stands for safety!
QUESTION? Does our XLR set on a C5 or C6 Corvette frame?
Dan & Wendy
"05 GRAND DADDY"
The C5 and C6 frame/chassis were used though I'm not sure when the C6 was first used.
C6 Corvette was started for the 2005 model year run,,,but production of that vehicle was:
[TABLE="class: infobox hproduct, width: 22"]
<TBODY>[TR]
[TH="align: left"]Production[/TH]
[TD]2004–February 28, 2013[/TD]
[/TR]
</TBODY>[/TABLE]
So I'd assume that maybe all XLR's are on the C6 frame?
Found this on the C6 forum,,,,
Hope the picture shows up.....had trouble earlier posting a picture
Another method for jacking / lifting / supporting C6 - PICS!!! - Corvette Forum
<tbody>[TR]
[/TR]
</tbody>[/TABLE]
Thanks but what frame do you think the 2004 XLR's produced in 2003 & 2004 was used?
All xlr chassis are the same.GM used a modified c5 chassis for the xlr and the c6 corvette. :) Al
OK, so if I have all of this sorted out, it should be fair to say that the C6 was built on the XLR frame, since our cars came first. :chuckle
(Just stirring the pot a little, yano...) :(
I still don't know! I'm really confused now so many different opinions lol! So is my 05 on the C5 or C6
Dan & Wendy
"05 GRAND DADDY"
Dan & Wendy
"05 GRAND DADDY"
There are very minor differences between a C6 Chassis and an XLR Chassis, but they are different with the XLR having some additional holes. The Main Frame of a C6 and C5 are very similar. Unless you start talking about the ZR-1:)
From Corvette Forums about C5 v. C6 frames:
The biggest difference that I know of it the rear sub-frame, control arms, and spring mounting are different. That's how they lengthened the wheelbase going from a C5 to a C6. The rear leaf spring on a C6 mounts the same as the front, as opposed to the method the C5 used.
The channeling around the door jams is different, and the frame IN FRONT of the front wheels is short, but the frame itself and subframes are pretty much the same.
HTH
Hi Tim, let me expand on this, you can say the c6 was built on the xlr frame BUT let's go back. the xlr frame is a modified c5 frame. c6 frame is modified from xlr. so to review: xlr built from c5, 1 1/2 inches longer for the N* eng. c6 built on xlr frame?? remember the xlr/c6 frames are about identical and were eng.for both vehicles. It's like the chicken or the egg?? that's the info I have from the XLR book.?? someone else jump in the pot w/ more info.:laugh: Al
Dan & Wendy
"05 GRAND DADDY"
I agree with 05 granddaddy. So my 06 is on the c6 chassis. :lol:
I love this forum with all the helpful info.
