White chalky residue on dash
Cadillac Tech
Cicero,Indiana
Document ID: 2225410
#PIC5072: White Chalky Residue On Interior Trim Panels Or IP Dash Pad - keywords appearance chalk color dark dash dust film instrument leather left pad panel right spot spots stain substance vinyl white - (Jan 20, 2009)
Subject:White Chalky Residue on Interior Trim Panels or IP Dash Pad
Models:2004-2009 Cadillac XLR models
2005-2009 Chevrolet Corvette models
Condition/Concern:
Some customers may comment of a chalky substance that is present on the interior trim panels. This is more commonly noticed on dark colored trim versus lighter colored trim. The release of this chalky substance is referred to as "Out Gassing" and can occur with plastic and vinyl materials.
Recommendation/Instructions:
DO NOT replace the trim panels to correct this concern. Clean the interior trim panels using Murphy's Oil Soap or an equivalent, non-acidic, cleaner. Replacing the trim panels does not guarantee this will not happen again.
Note: Murphy's Oil Soap can be purchased at most grocery stores. Follow the directions on the bottle for use.
© 2010 General Motors. All rights reserved.
Interesting, Bruce. I usually use Maguire's vinyl cleaner on the interior panels...I've never heard of using Murphy's oil soap on vinyl, usually use it on wood.
Same here, I think any mild detergent or interior cleaner (which is what I have used) will work.
... The release of this chalky substance is referred to as "Out Gassing" and can occur with plastic and vinyl materials...
Well, if that isn't just SCARY!!! We're breathing what? when are windows are up and the air is circulating???? :willy_nilly::willy_nilly::willy_nilly:
Thanks, Bruce. I was wondering why it was localized primarily on the dash and not all over the interior like a ventilation system issue.
Does the Murphy's close or seal the pores any to reduce future emissions in addition to cleaning?
I don't believe it will. Cleaning will remove the residue that is on the surface, but not eliminate it all together.
