BusaMan
Swaybar Installation - The Post Mortem
UPDATE. Well, I just HAD to try to get the anti-sway bar installed, so I gave it a whirl. I don't have the luxury of a lift in my garage, so I broke out the hockey pucks I had converted into jack pads, and got after it while my wife was off to the store. The makeshift pads worked fine, and soon the wheels were off the floor, secured also by an olde screw jack, 'cuz my jack stands wouldn't fit. [Note to self: get some decent jack stands.] After inventorying all the parts (they were all there, except for the afore-mentioned instructions) and laying this all out, I got going.
The 1st thing I discovered is that I was missing an 18mm deep socket. How? Where? Dunno. Had to use a 3/4", which was loose, but got the nuts off that A-frame mounting bolt OK. AOK so far. There was no lube at all on the "isolator", so I gave it some silicon spray, and I slipped the isolators on the bar just fine. With the help of some more spray and a big rubber hammer, I got the clamps over the rubber isolators and put the bar on the car, loosely. I had to refer to the pic's posted here to confirm how the links went on. Thought I'd just put them on loosely, do a final adjust and torque 'em down. NO WAY.
The nuts for the links only thread on about half way, and then they get really hard to move, and the link "bolt" fittings turn. It looked like a thin 18mm open end wrench would stop that, so I tried that. No joy there; after a few more turns [not enough], the little backing part of that "bolt" spun on the wrench, and wouldn't hold after that. My only recourse at that point was one I deplore: Vice Grips. So, I put out my old faithful set I've had since the '60's and it did the job and I got the nuts [finally, after many "blue" words and about an hour] torqued to the spec's you gave me.
Lessons learned:
1) This job would be trivial for a dealer tech. They'd have the lift and probably the directions and the special 18mm backing wrench needed to keep the link "bolts" from turning. Really should not take them over 0.3 hours for the installation.
2) Don't still be using the whole garage when your wife gets back home, and cause her to have to "donkey" all the groceries from the driveway.
Now to give QUIK AG a test drive a little later.
Tim
I'll check tomorrow and see if I still have them; under the weather today with a cold/bug. If I can't find them, I'll check my service manual, and go that route.
Lessons learned:
Tim
